Jul 16th, 2024, 1:37pm
how to generate a user-defined AC source? (Read 3598 times)
sugar
Jan 23rd, 2007, 3:38am
In spectre AC simulation, I want to generate an AC source whose output is defined as follows,
out = (-1) - 10 * sqrt( f / 0.825 ),
how can I do that?
topquark
Thames Valley, UK
Re: how to generate a user-defined AC source?
Reply #1 - Jan 23rd, 2007, 6:19am
First off, I'm not sure what you call "AC source" is sinusoidal!
analogLib has pure sine wave sources vsin or vsource or even exponential sources vexp
There's also a vsffm source; don't know if it can be used for your purpose.
For such custom voltage sources, i guess we need to write ahdl/veriloga code to create a block that takes in arbitrary functions for amplitude and frequency
-Gau
Frank Wiedmann
Munich, Germany
Reply #2 - Jan 23rd, 2007, 7:26am
It will probably be much easier to use an AC amplitude of 1 and to multiply the result of the AC simulation by your factor. Because AC simulation is linear, the results will be the same. You can get the frequency with the xval() calculator function, using any voltage or current in your circuit as argument.
sugar
Reply #3 - Jan 23rd, 2007, 8:31pm
topquark and Frank Wiedmann,
thank you for your replies.
Using calculator is not a good method for my case, because I need an AC source, not manipulated simulation result.
I have tried to use verilog-A to model it, but the results are strange. Following is a simple verilog-A model, just for test.
module ac_src(freq, out);
  input freq;
  output out;
  electrical freq, out;
  real varOut;
  analog begin
     varOut = V(freq);
     V(out) <+ ac_stim("ac", varOut);
In above model, freq is a input pin whose value is proportional to simulation frequency.
The simulation results alway show
mag(VF("/out")) = 0
phase(VF("/out")) = 0
what's wrong with my model?
