Jul 17th, 2024, 12:38am
Using S-parameter files in Spectre (Read 4429 times)
chip
Jan 23rd, 2007, 6:02pm
When we use Spectre simulation for such as noise figure and phase noise, can we use S-parameter files? Or it can NOT and the passive devices such as inductors must be included as a physical-meaningful model?
Thanks a lot.
ACWWong
Oxford, UK
Re: Using S-parameter files in Spectre
Reply #1 - Jan 24th, 2007, 4:25am
Yes, this topic has been covered very recently on this forum. Try doing a search or try:
http://www.designers-guide.org/Forum/YaBB.pl?num=1169004722/3#3
chip
Reply #2 - Jan 24th, 2007, 7:43am
Thank You Very Much Grin
chip
Reply #3 - Feb 2nd, 2007, 12:32am
There is a problem when we use S-paramter file in Spectre simulation such as for phase noise and noise figure, because the simulator DO NOT know the "physical meaning" of the S-parameter--such as it does not know the impedance comes from a resistor of a inductance--for the later case, there is no noise from it. So for such kinds of simulations,we must use physical model in simulation. Yes?
Reply #4 - Feb 2nd, 2007, 1:47am
Hi.
Touchstone format data have noise paramers as option.
However without this noise parameter option, S-parameter generates
thermal noise.
If you need additional noise other than thermal noise, you should add noise parameter.
This is true if your S-parameter boxes are some active device circuits.
