chip
There is a problem when we use S-paramter file in Spectre simulation such as for phase noise and noise figure, because the simulator DO NOT know the "physical meaning" of the S-parameter--such as it does not know the impedance comes from a resistor of a inductance--for the later case, there is no noise from it. So for such kinds of simulations,we must use physical model in simulation. Yes? Thanks
