Aug 15th, 2024, 9:42am
Bsim VerilogA model and AC analysis (Read 1378 times)
NanoMilton
Jan 24th, 2007, 2:23pm
Is there a Verilog A Version of BSIM model? If so, where can I find it? Also, it is not possible to run analysis with model implemented in Verilog A,isn't it?
Thanks a lot.
Re: Bsim VerilogA model and AC analysis
Reply #1 - Jan 25th, 2007, 4:48am
Silvaco (now simucad)  has "not for commercial use" bsim3 and bsim4 verilog-a models, available (last I checked) after registration from their web site.  (I think there's a link if you click Verilog-AMS from the nav bar of this site.) Others have done the translation, also, but I don't think they've put them out for the public.
If your simulator supports Verilog-A, it should support Verilog-A for any analysis type, so I'm not sure I understand your second question.
NanoMilton
Reply #2 - Jan 26th, 2007, 11:48am
Thanks a lot. I got the BSIM models from the web.
With regard to my second question, I remember that there is a post somewhere in this forum saying that Verilog A doesn't support complex number calculation. Actually, what I want is to run a frequency domain analysis on my model so as to characterize it's ac behavior. Is it possible to do so?
Reply #3 - Jan 26th, 2007, 12:39pm
You can run an ac analysis with a Verilog-A model.  The complex numbers are handled by the simulator -- it linearizes the equations in the Verilog-A model, and capacitive terms get multiplied by j ω.  The Verilog-A model itself does not have any complex numbers in its equations.
NanoMilton
Reply #4 - Jan 26th, 2007, 12:53pm
So, to describe a capacitor, I use the statement:
I(Drain,Source) <+ ddt(Cds*V(Drain,Source));
Does the simulator automatically know that it's a capacitor?
Reply #5 - Jan 29th, 2007, 4:32am
NanoMilton wrote on Jan 26th, 2007, 12:53pm:
Yes.
Actually, probably the better way to describe what happens is: the simulator sees the "ddt" operator, which has a Fourier transform involving multiplication by j ω, which is used to compute the frequency response of the linearized system.
