Oct 2nd, 2026, 6:02pm
How to limit .raw file size in MDL? (Read 3951 times)
topquark
Thames Valley, UK
Jan 26th, 2007, 2:41am
Hi Folks,
I've started using MDL for a lot of my measurements.
It's quite handy, offers a lot of features but I noticed it hogs my disk space very quickly(esp. when using 'foreach' loops)!
I traced it to the fact that the .raw file contains voltages at all nodes & currents through all elements!!
How can I choose specific nodes to be output like we do in OCEAN using-
saveOption( '..." )
I couldn't find any info about this in the user manual.
Anybody has a clue?
gau
Scott Flinchbaugh
Re: How to limit .raw file size in MDL?
Reply #1 - Jan 26th, 2007, 3:47pm
Gau,
The easiest way to accomplish this is to add the following to your options statement in the spectre netlist:
"save=nooutput".  This is a relatively new feature, so it may or may not be available with your release.
An alternative method is to explicitly save only one signal in the netlist.  That will still generate raw files
for that particular signal, but should reduce your output.
Hope this helps,
-scott
View Profile flinchba   IP Logged
topquark
Thames Valley, UK
Reply #2 - Jan 29th, 2007, 12:49am
Scott,
Thanks for your reply-
I tried adding the statement "save=nooutput" in the netlist file(.scs) but it's not being recognized.
So, I tried commenting the line
saveOptions options save=all pwr=all currents=all
Now, the .raw file was reducedin size, just containing some node voltages and currents thru some elements.
But, how do I specify any particular node/element I need to be output?
Could you please show me the syntax in the above.
Gau
topquark
Thames Valley, UK
Reply #3 - Jan 29th, 2007, 5:26am
Solved!
I just specified the voltage nodes and current elements in the schematic, extracted the netlist in ADE
It appears as
save Vin C0:1 R8:1 Vout
saveOptions options save=selected pwr=none currents=selected
Now, even MDL simulations produce raw o/p with the selected nodes & elements.
Thanks Scott!
Gau
