Nov 8th, 2026, 2:48am
errors when compiling modules from ahdlLib (Read 6457 times)
Na Kong
Jan 27th, 2007, 3:03pm
It says:
Compiling
/software/Cadence/IC5141/tools/dfII/samples/artist/ahdlLib/ind/veriloga/veriloga
.va in cellview ahdlLib.ind:veriloga
ncvlog: 05.81-p002: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
ncvlog: *E,DLWRIT: Intermediate file for module ahdlLib.ind:veriloga (VST) could not be opened for writing (System error).
Verilog-AMS compile failed for  cellview ahdlLib.ind:veriloga
Does it mean the modules should be writable first, then can be compiled? But that isn't reasonable.  Could anybody tell me how to deal with this? Thanks a lot!
Na
Re: errors when compiling modules from ahdlLib
Reply #1 - Jan 28th, 2007, 2:13pm
There are two solutions - one is to run "amsLibCompile" in <instdir>/tools/dfII/bin. This will compile all the Verilog-A libraries in the DFII installation. This is a configuration step during installation, but you can run it afterwards. To do this though, you'd need write access to the library.
The other approach is to add:
ASSIGN ahdlLib TMP ./ahdlLib_tmp
into your cds.lib file. This tells it to use ahdlLib_tmp in the working dir as a writable temporary directory for derived data from the ahdlLib - and so ncvlog will be able to compile into that.
Na Kong
Reply #2 - Jan 28th, 2007, 6:03pm
Many thanks!
Na
