Oct 6th, 2024, 3:41pm
Two Stage Opamp (Read 2571 times)
hande.vinayak
BOM
Two Stage Opamp
Jan 31st, 2007, 1:23am
Hi to all,
   If u go through simple two stage opamp design,in that case can see that gm6 = 10*gm6 (approximately):where
gm1 = trnscounductance of one of the i/p pair trnsistors &
gm6 = trnscounductance of 2nd stg i/p trnsistor.
   My doubte is if we want 60 deg PM,why we are selecting only 10 as a multipying factor why not other one?
In Holberg,he has given explanation for cc > 0.22 * (cload).Buut npthing for transconductance related anything.
   Please,can anybody guide me in this regards?
   Thnx.
avlsi
singapore
Re: Two Stage Opamp
Reply #1 - Feb 26th, 2007, 1:15am
I think Cc = 0.22 X CL is a kind of value from experience. Infact, gm6=10Xgm1 is also from experience based on specs. Your output stage gm is dependent on SR also.
Winners never Quit,Quitters never Win
aamar
Re: Two Stage Opamp
Reply #2 - Feb 26th, 2007, 8:20am
avlsi yes we can get everything through experience but you have to search for the scientific meaning too.
the answer to the question is:
the 2 stage opamp has a right hand side zero which can cause for us stability problem, so to overcome it you have either to bring it to the left hand side using a compensation resistance with the miller capacitance or to keep it in the right hand but move it far away from the W0db (i.e. 10*W0db)
as the Z (zero) = gm6/Cc   , and the W0db=gm2/Cc = GainBW product (approx.)
so gm6 should be 10 times larger than gm2.
GBW= Gain * BW = Gain*P1 = (A1*A2) * (1/A2*Cc*R1)   where A1 is the gain of the first stage = gm1*R1 and R1 is the output resistance of the first stage.
so the result will be = gm1*R1*A2 / A2*Cc*R1 = gm1/Cc = gm2/Cc  where 1,2 are the input symetrical differential transistors.
aamar
