Jul 19th, 2024, 6:38pm
time measurements in SimVision (Read 2554 times)
Pavel
Lausanne/Switzerland
Jan 31st, 2007, 6:59am
Hello
How to measure time between 2 pulse transitions in SimVision.
by default, tool measures time between active cursor and baseline.
But baseline cannot be stuck to edge.
I didn't find how to measure time between 2 cursors.
Regards.
Pavel.
jbdavid
Re: time measurements in SimVision
Reply #1 - Feb 1st, 2007, 1:58am
you can add a second cursor, or drag the baseline to the time point you want to use as your referecne
jbdavid
Pavel
Reply #2 - Feb 1st, 2007, 2:21am
Thank you for answer
I didn't find how to measure between 2 cursors.
Baseline can't be alligned precisely (stuck) to pulse edge.
Regards.
Pavel.
zhong
California , United States
Reply #3 - Feb 3rd, 2007, 11:46am
Pravel,
You can do that. It's easy as bellow .
You have TimeA cursor as default . You can creat a new cursor in Simvision call TimeB (See a little pull-down field in upper-left corner of simvision)
Both TimeA and TimeB can stick with edge.
Say you fixed the timeA first and move move TimeB to next stage .
Again in upper left side of simvision, you can change the time delta from Cursor - baseline to cursor - timeA
Hope this helps
Zhong
Pavel
Reply #4 - Feb 5th, 2007, 4:51am
Thank you for answer Zhong.
Maybe we use different packages, because I didn't find option you proposed.
Could you attach some picture that shows your approach.
Regards.
Pavel.
zhong
Reply #5 - Feb 5th, 2007, 1:17pm
In simvision upper left , click the down-direction arrow along with Cursor-baseline . A pull down show up , then select "delta" , then define the delta to be "cursor - timeA"
zhong
Reply #6 - Feb 5th, 2007, 1:18pm
See attached pic.
Pavel
Reply #7 - Feb 6th, 2007, 1:30am
Where ? (please see the picture)
zhong
Reply #8 - Feb 6th, 2007, 6:47am
Looking your picture , It seems to me you are using very old version of simvision. Update to IUS57 or IUS58 , You can see the little arrow along with cursor-baseline and do what I mentioned in previous reply.
(Sorry,  somehow, I am not able to attach the picture from my disk.)
Pavel
Reply #9 - Feb 8th, 2007, 4:48am
My SimVision version is 05.50-s008
zhong
Reply #10 - Feb 8th, 2007, 9:40am
IUS55-s008 is too old . Please  update to IUS57 or IUS58 to see what I described in simvision.
The latest version of IUS is IUS583-s001 .
