Jul 16th, 2024, 3:42pm
Upsampler (Read 4522 times)
shirin_br
The Netherlands
Upsampler
Feb 02nd, 2007, 2:41am
Hello All,
I need to make the behavioral model for Upsampler with factor of L in verilog-AMS. But so far any function that I made did not work. I would appreciate anyone who has done the same, or maybe if has some suggestions, give some hints to me.
Thank you very much.
Re: Upsampler
Reply #1 - Feb 2nd, 2007, 5:07am
Did you try using the timer event?
shirin_br
The Netherlands
Re: Upsampler
Reply #2 - Feb 2nd, 2007, 6:09am
Yes, I did. But the problem is I should do it by adding zeros in between, two samples. So, there should be a function which gets the samples in the input, the sampling frequency and upsampling fatcor(L) as parameters.
Then it should work as this: divide the period time(T) by the factor, keep the sampled signal for T/L time, add L-1 zeros in each time interval of T/L and repeat this with the frequency of 1/T.
The problem with timer is that I can not use any analog operation inside it.
Re: Upsampler
Reply #3 - Feb 5th, 2007, 5:28am
shirin_br wrote on Feb 2nd, 2007, 6:09am:
You can't do a contrib, but you should be able to do a sample.
module upsamp(in, out);
  inout in, out;
  electrical in, out;
  parameter real T = 1u from (0:inf);
  parameter integer L = 4 from [1:inf];
  real vout;
  integer count;
  analog begin
    @(initial_step or timer(0, T/L)) begin
	if (count % L == 0)
	   vout = V(in);
	else
	   vout = 0;
	count = count + 1;
    V(out) <+ transition(vout, 0, T/(L*10.0));
I'm not sure if you want the transition there or not, or what the rise time should be.  The timer should fire at the upsampling period (T/L) but only sample the input every Lth time, otherwise setting vout to zero.
shirin_br
The Netherlands
Re: Upsampler
Reply #4 - Feb 5th, 2007, 6:44am
Thank you so much for the help. I had made also something which was working as upsampler, but it was in 2 different blocks, so it was not the optimum solution. The main block was a simple sample and hold but it had a clock input with T/L duty cycle.
Thank you again,
/Shirin
