Aug 15th, 2024, 10:32am
How to send a string in a verilog-ams block (Read 2672 times)
shirin_br
The Netherlands
Feb 02nd, 2007, 4:07am
I'm making a block to work as a probe. So I want to send a file as input of the block and plot it. Some how I should manage to send the filename to the probe and ask for the output.
Does anyone know how to send a strng into a block? I could not find any thing in the book yet.
Thank you.
Re: How to send a string in a verilog-ams block
Reply #1 - Feb 2nd, 2007, 5:06am
Verilog doesn't support strings; SystemVerilog does.
String literals in Verilog can be handled as arrays of "reg" variables, where each character is an 8-bit value.  A little hard to use this, though, to open files.
jbdavid
Reply #2 - Feb 9th, 2007, 3:08am
I guess its NOT the same thing..
but I recently used the new Verilog-A string parameter on a block, which I set to a Design Variable so that I could change the filename from and Ocean script..
it works nicely..
parameter string myFileName = "Module_Output_file%D_%T.dat";
analog begin
 @initial_step("tran") begin
 FileHandle = $fopen( myFileName);
In verilog-D you can use a register to hold a string value, (8 bits/character)
and until the latest version supports string parameters, you can just leave the TYPE undefined
parameter myFileHandle = "myDefaultFileName.dat"
initial begin
filehandle = $fopen(myFileHandle);
But in digital side , at least in cadence the %T type code isn't supported in the $fopen.
jbdavid
