Oct 7th, 2024, 7:20am
My Doubt in LDO (Read 1423 times)
shankar_p
India
My Doubt in LDO
Feb 02nd, 2007, 10:03am
I am designing an LDO to produce a regulated 1.8V from an unregulated 3V supply with 50 mA as max current. For this the W/L of the Mosfet turns out to be around 2000.   For compromising this making the transistor to go in linear region will reduce the W/L drastically to around 100 but increase the gain of the error amplifier. So which one is a better design, use larger transistor or use the FET in linear region. Will i get any performance degradation if i use the FET in triode region?
