Sep 17th, 2024, 8:50pm
unwanted? paths (Read 3557 times)
aaron_do
unwanted? paths
Feb 05th, 2007, 12:01am
lets say you have an inverting amplifier at RF. Suppose there's an unwanted signal path which results in only 160 degrees phase shift as opposed to 180 degrees. At the output, these two signals combine.
How would this affect the throughput of a system. My initial thoughts are that it would not have much effect on an FM modulation system, but would affect a PM modulation system. Is this correct? I suppose it would also depend on the type of demodulation. I'm more interested in the theoretical/ideal world type answer.
thanks,
Aaron
mg777
Re: unwanted? paths
Reply #1 - Feb 8th, 2007, 11:11pm
From trig,  A1.cos(θ) + A2.cos(θ+δ) = A.cos(θ+φ)
where φ = tan-1[A2.sin(δ) /(A1+A2.cos(δ))], and A is the hypotenuse of the corresponding right triangle.
As long as A1 and A2 are constant, the phase shift φ is static and an FM demodulator can't tell it from propagation delay. The case of A2 ≪ A1 is obvious. But if you have some amplitude fluctuations prior to clipping, then there'll be a time varying φ due to AM-PM conversion.
The effect of a time varying φ on FM can be difficult to calculate - depends on whether the FM is for analog (voice) or digital (FSK/GMSK/CPSK). If you have CPSK with modulation memory and a trellis coding layer, it becomes a serious question for a communications theorist. In my understanding, FM and PM are the same beast - in one the message is integrated, in the other it is not. In an FM demodulator you need to count periods to tell what the frequency is, so you end up integrating somewhere.
M.G.Rajan
www.eecalc.com
aaron_do
Re: unwanted? paths
Reply #2 - Feb 9th, 2007, 6:04am
thanks for the reply,
I'll look into that further. I'm really interested in the different types of modulation and how you design around them, but every time i finish reading a section in my digital and analog communications systems book i forget it before i pick the book up again......
Aaron
aaron_do
Re: unwanted? paths
Reply #3 - Mar 7th, 2007, 5:44pm
Hi Mr. Rajan,
thanks for your help.
regarding the formula you derived, I have a slight correction...
A = √(A12 + 2A1A2cosδ + A22)
cheers,
Aaron
