Jul 22nd, 2024, 11:20pm
BRIEF, NXX Statement in Hspice (Read 7301 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Feb 05th, 2007, 12:55am
I am studying Hspice right now. In Hspice manual it says like this:
BRIEF, NXX: Stops printback of the data file, until Hspice finds an .OPTION BRIEF=0, or the .END statement. It also resets the LIST, NODE, and OPTS options, and sets NOMOD. BRIEF=0 enables printback. NXX is the same as BRIEF.
But I still can't understand this kind of explanation, what does "printback of the data file" mean here, and what's NXX? Thank you in advance!
Terry
Re: BRIEF, NXX Statement in Hspice
Reply #1 - Feb 5th, 2007, 5:32am
When you run HSpice, it usually echoes the entire input file -- and included libraries! -- to stdout, or to the log file.  Often, you don't care to see the libraries spewed to the screen.  The manual is saying you can:
.OPTION BRIEF
or
.OPTION NXX
and get the same behavior (suppress echoing).
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #2 - Feb 5th, 2007, 6:10am
Geoffrey_Coram wrote on Feb 5th, 2007, 5:32am:
.OPTION BRIEF
or
.OPTION NXX
Hi Geoffrey, do you know what does NXX stand for here, BRIEF means brief, but how about NXX, I really can't guess out where do these acronyms come from.
Reply #3 - Feb 5th, 2007, 2:08pm
qiushidaren wrote on Feb 5th, 2007, 6:10am:
No idea.  Could be from some obsolete simulator, lost to history ...  In HSpice, some of the device aspects (cgs, gm, gds) are also known by odd names like LX20.
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #4 - Feb 5th, 2007, 5:18pm
Geoffrey_Coram wrote on Feb 5th, 2007, 2:08pm:
Got it, thank you.
-Terry
OldHouseBlues
Massachusetts, USA, Earth
Reply #5 - Feb 8th, 2007, 6:24am
Regarding the "odd names like LX20", this is an HSPICE feature described as "element
template output" in the HSPICE Simulation and Analysis User Guide. It allows the user to:
"...output user-input parameters, state variables, stored charges, capacitor currents,
capacitances, and derivatives of variables."
Reply #6 - Feb 8th, 2007, 11:20am
OldHouseBlues wrote on Feb 8th, 2007, 6:24am:
Regarding the "odd names like LX20", this is an HSPICE feature described as "element template output" in the HSPICE Simulation and Analysis User Guide.
But why LX20?  How on earth is a designer supposed to remember that LX20 is Cgs not Cgd or gm?  Hmm, let's see, the top 20 things I'm likely to want to know about my device are: id, is, ig, ib, ... qd, ... dang, do the q's come before or after the c's?
John O Donovan
San Jose, CA
Reply #7 - Feb 8th, 2007, 2:31pm
I think that the LX/LV numbers are from the layout of the instance data structures in SPICE2. The number was the index into an array I think (or something similar).
 John
Reply #8 - Feb 8th, 2007, 6:56pm
Geoffrey,
You don't have to use the obscure, hard to remember, element numbers in HSPICE these days. You can just do:
.PROBE CGSBO(M1)
Rather than LX20. Each of the element templates has an equivalent meaningful name.
Reply #9 - Feb 9th, 2007, 6:29am
Andrew Beckett wrote on Feb 8th, 2007, 6:56pm:
I know; this sub-thread got started with "what does NXX mean?"
I wonder if LX20 originated from the Spice2 Fortran code ... I don't recall seeing it in Spice3's C code.
