I have a question concerning the matlab code from Ken's Paper "Predicting the phase noise and jitter of PLL-based frequency synthesizers" that computes the phase noise PSD from periods data. During my simulations and analysis I found a difference of 3dB in the phase noise spectrum (Sphi) from the matlab output and the expected value. I used the parameters from the example in Ken's paper on page 44.
VCO: L(100kHz)=-48dBc/Hz and thus Sphi(100kHz) =-45db/Hz
fc=2GHz
using the equation
J
2=Sphi/2*(100kHz)
2/(2GHz)
3this leads to a period jitter of 4.45ps.
I generated periods with accumulating jitter with the matlab skript:
Code:%% Generation of accumulated jitter data
T=0.5e-9;
Jvar=4.45e-12;
t=0; %absolute time of rising edge
tprev=0; %previous time of rising edge
imax=100000;
i=1;
periods=zeros(imax,1);
for i = 1:imax
t=tprev+T+Jvar*randn(1); %accumulating jitter
periods(i,1)=t-tprev; %periods
tprev=t;
save acc_jitter.dat periods -ASCII;
and calculated the phase noise PSD Sphi with the skript:
Code:%%Calculate Sphi
nfft=2^12; %number of fft points
winLength=nfft;
overlap=nfft/2;
winNBW=1.5;
load acc_jitter.dat;
periods=acc_jitter;
peri_lenght = length(periods);
% output estimates of period and jitter
T=mean(periods);
J=std(periods);
maxdT = max(abs(periods-T))/T;
fprintf('T = %.3gs, F = %.3gHz\n',T, 1/T);
fprintf('Jabs = %.3gs, Jrel = %.2g%%\n', J, 100*J/T);
fprintf('max dT = %.2g%%\n', 100*maxdT);
fprintf('periods = %d, nfft = %d\n', length(periods), nfft);
% compute the cumulative phase of each transition
phases=2*pi*cumsum(periods)/T;
% compute power spectral density of phase
[Sphi,f]=psd(phases,nfft,1/T,winLength,overlap,'linear');
% correct for scaling in PSD due to FFT and window
Sphi=winNBW*Sphi/nfft;
% plot the results (except at DC)
K = length(f);
rbw = winNBW/(T*nfft);
%norm to resolution bandwidth
Sphi_norm=Sphi/rbw;
figure;
semilogx(f(2:K),10*log10(Sphi_norm(2:K)));
title('Normalized Power Spectral Density of Phase');
xlabel('Frequency (Hz)');
ylabel('S phi (dB/Hz)');
RBW=sprintf('Resolution Bandwidth = %.0f Hz (%.0f dB)',rbw, 10*log10(rbw));
imtext(0.5,0.07, RBW);
grid on;
The output gives a period jitter of 4.45 ps (same as input), but a Sphi of
-68 dB/Hz @ 10^6Hz
-48 dB/Hz @ 10^5Hz
and so on.
Oviously there is a difference of 3dB (factor 2) in the PSD compared to the analytical equation.
Maybe this is due to the normalization to resolution bandwidth which is not correct.
Does anybody have an idea where the 3db (factor 2) are missing?
Thank you very much
