Sep 17th, 2024, 2:18pm
S/H droop (Read 775 times)
Croaker
S/H droop
Feb 05th, 2007, 5:45am
The capacitor voltage droops due to Ioff of the switch, the reverse-biased drain diode of the switch, and substrate current.
I'm not seeing how substrate current comes into play.
dkace
Re: S/H droop
Reply #1 - Feb 13th, 2007, 1:10am
What if substrate current results on a lower Id  and therefore a voltage drop across the switch, which eventually is presented as a voltage drop on the capacitor controled by this switch? What I am saying is that this is not  adirect effect of the capacitor charge rather than on the MOST itself.
What do you think?
D.
Croaker
Re: S/H droop
Reply #2 - Feb 13th, 2007, 7:56am
I don't know.  Hmm, I'm sure if I scrounge through my library I can find an explanation.  Usually you need a few books on each subject to cover all the gaps one author creates.
