Jul 23rd, 2024, 7:10am
Feature like IFDEF for Spectre? (Read 4365 times)
Daniel_Platte
Munich/Germany
Feb 06th, 2007, 7:04am
I would like to change Spectre netlists controlled by an environment variable within a script-automated simulation. Is there a feature like IFDEF for the Spectre netlist parser? How can I access environment variables within the netlist?
Example:
-> if $DEBUG is set, add additional netlist entries to the simulation
Daniel
bernd
Munich/Germany
Re: Feature like IFDEF for Spectre?
Reply #1 - Feb 6th, 2007, 8:14am
In my opinion this is not directly possible within the
Analog Environment. I would use a programming language
either SKILL or PERL to parse the netlist after it's creation and
make the modification.
Bernd
Just another lonesome cad guy
Reply #2 - Feb 6th, 2007, 4:17pm
If using spectre from the command line, you can use the -E option to spectre to tell it to use the C preprocessor before spectre parses it.
For example:
#ifdef MYDEF
// something you want to include
#endif
You can then use spectre -E -DMYDEF mynetlist.scs to pass in particular definitions from the outside.
Daniel_Platte
Munich/Germany
Reply #3 - Feb 7th, 2007, 12:48am
Thanks for the advice!
Unfortunately, the C-preprocessor does not evaluate Spectre's include statement. As I would need the #ifdef in an options file (that is typically included with Spectre include), the C-preprocessor does not evaluate the #ifdef. Replacing all includes by #include does not solve the problem (and would be very tedious). Shouldn't the C-preprocessor evaluate the #include statements?
Is it possible to combine Spectre's include and the #ifdef directive?
Reply #4 - Feb 7th, 2007, 3:38am
The C preprocessor does process the #include statements. But it won't process any files which are included with spectre's include statements - because these are processed after cpp has done its job.
I can only assume you didn't replace all the includes with #includes?
