topquark
Thames Valley, UK
Arun,
You're right- usually the temp behaviour of caps are not modeled, in particular the varactor. They just have the voltage gradient specified in ppm/V In contrast, you've got the linear and quadratic tempco reported for a resistor.
What I did for a process was do a.c simulation with temp sweep and observed that tempco for mos-caps varies between +ve and -ve values. For LC-VCO design, you're better off doing such a simulation, just with the varactor and also the whole oscillator to see how temperature's affecting it.
Cheers, Gau
