Jul 19th, 2024, 8:25am
strange spectre error about -mixmod (Read 6917 times)
bbarnett
Feb 10th, 2007, 10:00am
I am trying to run a mixed signal simulation using spectreverilog as the simulator.  It sets up, but spectre seems to die.
When I attempt to execute runSimulation manually (file contains):
spectre  -env artist5.1.0 +escchars +log ../psf/spectre.out -format sst2 -raw ../psf   -I(correct model path) +lqtimeout 900 -maxw 5 -maxn 5 -mixmod -slvhost (correct hostname) '-slave"(correct path...)/config/netlist/digital verilog.vmx  -a +sxl_keep_minimum  +typdelays +gui -y ./hdlFilesDir +libext+.v+ +incdir+hdlFilesDir +sdf_verbose +sdf_nocheck_celltype -l verilog.log +vmxwavedir../../psf -f mmenvOpts testfixture.template -f verilog.inpfiles"' analog/input.scs
Any ideas as to why -mixmod isn't being accepted by Spectre?
Thanks!
I get the following:
Error found by spectre.
   Invalid command line argument `-mixmod'.
       Use `spectre -help' for more information.
Re: strange spectre error about -mixmod
Reply #1 - Feb 23rd, 2007, 2:36am
Very odd. -mixmod has been there for years.
Ah, I just did a bit of searching, and I think I know what the problem is. You are picking up the 64 bit version of spectre - and spectreVerilog is only supported in the 32 bit mode. Most likely you have the environment variable $CDS_AUTO_64BIT set?
Certainly if you do "spectre -64 -mixmod" it gives the error - for the same reason.
Reply #2 - Feb 26th, 2007, 9:37am
Andrew Beckett wrote on Feb 23rd, 2007, 2:36am:
That seems odd to me.  Why isn't is supported in 64-bit mode?
Reply #3 - Feb 26th, 2007, 10:53am
Because spectreVerilog is prehistoric, and is based upon Verilog-XL. Verilog-XL is not a supported Verilog simulator, and hasn't been updated for many years (it doesn't support Verilog 2001, for example).
So really spectreVerilog is supported for legacy reasons.
