Aug 15th, 2024, 6:06pm
PLL Phase Noise profile problem (Read 3024 times)
HFG
Feb 14th, 2007, 8:16am
Hello All,
Iam simulating schematic level simulations of phaselocked loops. I run PSS and Pnoise to generate the phaseNoise plot. Regardless of what type of PLL i design i get a phase noise slope of -10dBc/hz per decade but its suppose to be -20dBc/Hz per decade. I am pretty sure its not a circuit issume but a simulator problem. Will incorrect settings result in the wrong profile of the phase noise ? anyone run into this issue before ?
Re: PLL Phase Noise profile problem
Reply #1 - Feb 14th, 2007, 9:04am
Have you looked at the noise contributors summary? Where is the noise coming from?
savithru
Reply #2 - Jun 27th, 2007, 12:15am
Hi ken,
can you pls tell me how to look at the  noise contributors summary?
I could not find the menu in spectre RF.
SavithRu
Thanks & Regards
SavithRu
View Profile savithru savithru   IP Logged
