Apr 29th, 2024, 12:04pm
LNA voltage gain measurement method (Read 6177 times)
wccheng
Feb 15th, 2007, 6:20am
Dear all,
I know I could use Network analyzer to measure power gain (S21) of the LNA. If I want to measure the voltage gain of the LNA, how could I do it? Actually, I am using AC analysis in the simulation to see the voltage gain of the LNA. Is it correct?
wccheng
mg777
Re: LNA voltage gain measurement method
Reply #1 - Feb 18th, 2007, 11:07pm
You can easily convert from S to Y or Z, and obtain the voltage gain for given source and load impedances. If you are new to a network analyzer you may want to consult Agilent's app notes on de-embedding the signal connections for board as well as on-wafer measurements.
In simulation AC analysis should be adequate, but expecting the simulation to match measurement depends on how good your modeling is. Especially the supply bypass.
M.G.Rajan
www.eecalc.com
aaron_do
Reply #2 - Feb 19th, 2007, 7:29am
Unfortunately, using a network analyzer also means you have a 50 ohm load. As far as a i know you need to design a buffer with known gain, high input impedance and 50 ohm output impedance. At RF that's pretty tough to do.
-Aaron
mg777
Reply #3 - Feb 20th, 2007, 10:20am
If the cal is good the 50 Ohm load can be de-embedded, provided the amplifier is stable for the VNA set-up. That's the measurement part of it - the design is a different issue.
What is the sensitivity to an s22 cal error of δ? Assuming δ is real, then Zo is off by a fraction 2δ. The corresponding error in voltage gain would be (1 + 2.δ)(1 - 2.δ.Zo/RL). If the s22 cal is good for 30 dB (δ=0.03) the error in voltage gain for RL=250Ω is below 2%. A 30 dB on-wafer cal can be achieved out to 10 GHz even with an archaic SOLT substrate once the cables have warmed up.
M.G.Rajan
www.eecalc.com
aaron_do
Reply #4 - Feb 20th, 2007, 10:21pm
That was an excellent first pass analysis. For the actual voltage gain you'd have to find Zout using S22 and use the resistor divider concept to get the voltage gain.
I'm wondering though if you want to do noise measurements, how well de-embedded will the 50 ohm output port be after cal?
