Jul 16th, 2024, 2:54pm
laplace transform (Read 915 times)
Tommy
Tokyo, Japan
laplace transform
Feb 15th, 2007, 7:00am
How to implement a function like H(s) = 1 + as + bs^2 ?
laplace_nd in cadence spectre exits complaining that the order of denominator is not  same as numerator order.
Tom
Re: laplace transform
Reply #1 - Feb 15th, 2007, 11:51am
Are you sure you don't want H(s) = 1/ (1 + as + bs^2) ?
Reply #2 - Feb 15th, 2007, 1:25pm
In case you want your original transfer function rather than Geoffrey's, you can get it by using the laplace function to implement a voltage-to-current converter with Geoffrey's, and then place it in the feedback path of an ideal opamp configured as an inverting amplifier. That will act to invert the transfer function.
mg777
Reply #3 - Feb 18th, 2007, 10:52pm
To continue on the denominator theme, add a D(s) such that H'(s) = H(s)/D(s) has a bandwidth 3X larger than the signal you're emphasizing. A good choice for D(s) would be a 3rd order Bessel.
M.G.Rajan
www.eecalc.com
