Very nice explanation, Tawna.
However, it seemed to me that Thomas was saying he *doesn't* get the residual warning when the Verilog-A sensor is omitted. Did I read that right, Thomas? In which case, you might need to take a close look at the Verilog-A code and see if you're doing something funny there -- eg, if the sensor output is the wrong order of magnitude for the tolerances, like you have an output voltage that is 1e-9 but you have a voltage tolerance of 1e-6.
