Sep 18th, 2026, 5:05pm
PSS simualtion for oscillator in ocean script (Read 2819 times)
boa
Feb 16th, 2007, 7:42am
I would like to run PSS simulation for oscillator over corners using ocean script.
How can I include the simulation in the script?
E.g. PSS setup in the netlist is as follows (mclk is the node where oscillation is measured):
___________________________________________
pss  (  mclk  0  )  pss  fund=75k  harms=60
+    errpreset=conservative  tstab=100u  saveinit=yes  method=trap
+    annotate=status
Normally I would use "analyses" and "run" statement in the script.
E.g. for transient:
analysis('tran ?stop "200u"  ?errpreset "conservative")
run()
However I always get error emssage when I try to combine these two..
Something like "undefined function" etc.
What's the proper way of doing it?
Re: PSS simualtion for oscillator in ocean script
Reply #1 - Feb 23rd, 2007, 2:24am
Well, it would help if you actually showed what you'd tried, and the actual error message.
The easiest way to get a starting point for your OCEAN script is to set it up in ADE, and use Session->Save OCEAN Script.
