Jul 19th, 2024, 6:31am
"System Verilog" import (Read 10662 times)
Pavel
Lausanne/Switzerland
Feb 19th, 2007, 2:47am
Is there a possibility to import "System Verilog" code?
Pavel.
Re: "System Verilog" import
Reply #1 - Feb 19th, 2007, 4:38am
Import it into what?  A simulator?  (Many 1364-Verilog simulators already support portions of the SV extensions.) A schematic editor? (Some tools have a Verilog-in mode so you can try to make sense of Verilog netlists.)
Pavel
Reply #2 - Feb 19th, 2007, 5:01am
As cell in Library Manager to be used as Test Bench.
I tried already Verilog-In. But in System Verilog there are constructs that aren't supported by Verilog/Verilog 2001 parser.
So import didn't pass.
Regards.
zhong
California , United States
Reply #3 - Feb 23rd, 2007, 12:44am
Pravel ,
You can not import SystemVerilog via VerilogIn today. VerilogIn basically is using ncvlog without -sv option as a paser . Parse/Compile SystemVerilog requires -sv option in ncvlog .
If you want to get SystemVerilog into DFII view , do following
ncvlog -sv -use5x  -work mylib  my_systemVerilog_file.sv
It will create DFII cell view under mylib.
Zhong
Pavel
Reply #4 - Feb 23rd, 2007, 4:15am
Thanks Zhong,
It worked. Cell was created with module view.
Regards.
Pavel.
Pavel
Reply #5 - Feb 23rd, 2007, 4:42am
Problem is partially resolved.
This command only get cell in Library Manager as module view. When I compile it features specific to System Verilog (for example logic keyword provoke errors.
Should I run some command in icms in order to set System Verilog support for parser?
Regards.
Pavel.
zhong
Reply #6 - Feb 25th, 2007, 8:55pm
There is no special env varible today in GUI flow to handle SystemVerilog.
The problem you have is that ,
    you compile the SystemVerilig text into DFII view use -sv  --- works fine
After that ,
    In AMS-ADE or AMS-HED , the GUI flow will RE-COMPILE the SystemVerilog  without -sv option.
    ---- This explains why you have problem.
The workaround is to
1. Compile all your SystermVeriliog to a exclusive lib which only have SystermVerilog
    for example
     ncvlog -use5x -sv -work my_systemVerilig_lib  my_systemVerilog_file.sv
2. In GUI flow (either AMS-ADE or AMS-HED)
   add my_systemVerilog_lib in the  "exclude libs list for compilation"   . You can find this field in the Compilation option form .
   This will avoid GUI re-compile the systemVerilog without -sv option.
BTW, if you change your IUS version , You need to re-do
to ensure the version of IUS you are using in command compilation is same as GUI flow.
Hope this helps ..
Zhong
Pavel
Reply #7 - Feb 26th, 2007, 2:20am
Thank you for answer, Zhong.
If I properly understood, once System Verilog cell is get to HE, I cannot change its code and compile in HE.
I have to use command line.
Regards.
Pavel.
zhong
Reply #8 - Feb 26th, 2007, 9:03pm
Pravel,
Your understand that corretly. As of today, GUI flow default does not issues the -sv for the compilation.
However you can add -sv in the additional compilation option in GUI . Now the issues will be -sv will be apply for all the text file (verilog/SystermVerilog/verilog.vams (generated from schematic) , the problem then is NC  does not allow you have co-existence of   -sv -ams option in the same ncvlog compilation line. This will cause the compilation failure on verilog.vams netlsit which generated from schemaitc.
What you can do is to
1. Once you have changed the SystemVerilog . Compile that from Command line
or
2. Add -sv in the GUI compilation option ,
  then surgically compile the SystemVerilog cell only in HED
  after that remove -sv from GUI option, add the systemVerilog lib in the Exclude list
  compile all
I would suggest you to go with solution 1>. It's much esaier than 2.
Zhong
