What simulator are you using? That's fairly important information...
Also, what version of the simulator are you using?
I can't think of any reason why spectre would do this, for example. spectre will put a breakpoint at each point in the pulse source.
Can you post the line in the netlist representing the pulse source? That may give some clues.
