Oct 5th, 2024, 6:16pm
VCO question (Read 4751 times)
YeeQ
VCO question
Feb 23rd, 2007, 10:45pm
I have a question about making VCO stop oscillating.
When doing 3-stage VCO design, I want to verify that - when low frequency gain of the delay cell is smaller than 2 (i.e. 6.02dB), the VCO will stop oscillating because the insufficient gain.
I run AC simulation on one delay cell (with parasitic loading), tuned the bias voltage to make it gain=5.45dB (<6.02dB). Then, I applied the bias voltage on VCO, however, the VCO doesn't stop oscillation.
The DC operating point is set at where the input common mode close to output common mode.
I don't know what I missed in the simulation, please help, thank you!
Re: VCO question
Reply #1 - Feb 28th, 2007, 9:53pm
I don't think that is a correct condition that makes the VCO stop oscillate. Would you please explain it?
Yawei
YeeQ
Re: VCO question
Reply #2 - Mar 2nd, 2007, 12:13pm
assume one-stage transfer function is A0/(1+S/w0), three stages would be H(s)=A0^3/(1+S/w0)^3
To achieve oscillation,
1) phase shift of each stage is 60deg. i.e. fosc=f0 * sqrt(3)
2) at oscillating freq., |H(s)|>=1. Applying condition 1), min. A0=2 (i.e. 6.02dB)
I wonder if my AC simulation setup is not correct. For the inputs to the diff. pair, vin is connected to DC common mode voltage, vip is connected to an AC source (with DC common mode voltage).  or should I connect both inputs vin and vip to two seperated AC sources?
YeeQ
mg777
Re: VCO question
Reply #3 - Mar 2nd, 2007, 12:41pm
The oscillation frequency needs to be determined by a resonant element. In a digital ring oscillator the oscillation frequency is determined by the loop delay, but an analog oscillator can build up the wiggles out of noise. By 'out of noise' I mean that the 'template' signal comes from the bandpass filter acting on noise, the energy for the oscillation has to come from the negative resistor.
In fact your circuit sounds like the Wien bridge oscillator:
http://en.wikipedia.org/wiki/Wien_bridge_oscillator
I didn't know that Hewlett (of HP fame) is credited with making Wien's idea work, neat stuff with the lightbulb.
M.G.Rajan
www.eecalc.com
fonseca.ha
UK
Re: VCO question
Reply #4 - Mar 6th, 2007, 4:58am
Just for some cross checks:
Does the oscillator oscillate at the same frequency that resulted in 60deg phase margin when making the AC sim?
I think that analisys may not correlate because the AC is computed from the small signal analisys at a given DC point, and nomally ring oscillators have big swings and cannot be treated as operating in a linear region,
Humberto
adesign
Re: VCO question
Reply #5 - Mar 7th, 2007, 10:27pm
fonseca.ha wrote on Mar 6th, 2007, 4:58am:
Humberto
You are right Humberto. Initially, for small swings, we can say that the gain required is 2. However, when the swing goes large enough, the small-signal analysis is no longer valid and in that case the output frequency is given by 1/(2nT) where n is the no. of inverting stages and T is the delay per stage.
Hope it helps.
nandy
Timbuktu
Re: VCO question
Reply #6 - Mar 21st, 2007, 9:03am
Since the gain used here is only slightly lesser than 2, any disturbance anywhere (due to noise) would result in ringing for some period of time. Although in the small signal sense this oscillation isn't self-sustaining, the inverters pick up this disturbance and blow it up into a large-signal full-scale oscillation. So, I guess, your oscillator can potentially oscillate unless the gain of each stage is reduced well below 2.
