YeeQ
I have a question about making VCO stop oscillating.
When doing 3-stage VCO design, I want to verify that - when low frequency gain of the delay cell is smaller than 2 (i.e. 6.02dB), the VCO will stop oscillating because the insufficient gain.
I run AC simulation on one delay cell (with parasitic loading), tuned the bias voltage to make it gain=5.45dB (<6.02dB). Then, I applied the bias voltage on VCO, however, the VCO doesn't stop oscillation.
The DC operating point is set at where the input common mode close to output common mode.
I don't know what I missed in the simulation, please help, thank you!
