May 19th, 2024, 7:41pm
Instantiating a built-in model (Read 3198 times)
VerilogANovice
Mountain View
Feb 25th, 2007, 3:03am
Can I instantiate a built-in MOS model from Verilog-A?
zhong
California , United States
Re: Instantiating a built-in model
Reply #1 - Feb 25th, 2007, 11:52pm
You can..
VerilogANovice
Mountain View
Reply #2 - Feb 26th, 2007, 12:39am
Do you know how to do that in HSPICE? I am not sure how I can read in the model card in Verilog-A.
Reply #3 - Feb 26th, 2007, 5:23am
The Verilog-AMS LRM does not specify how one defines model cards -- or the "library" for resolving model references -- in a Spice simulator.  You'd need to check with an application engineer from Synopsys to find out how this works in HSpice.
