Sep 17th, 2024, 2:24pm
synopsys DC synthesis problem (Read 5060 times)
qlmei
Feb 26th, 2007, 9:16pm
There is always "assign" statement in my verilog netlist after synthesis. I tried the following command before compile but it doesn't help. Please advise.
set_fix_multiple_port_nets -all -buffer_constants
set_simple_compile_mode true
set  hdlin_keep_signal_name  none
Re: synopsys DC synthesis problem
Reply #1 - Feb 26th, 2007, 11:04pm
Hi, qlmei,
I resolve this problem by define new naming rules before writing netlist out. Just like this :
define_name_rules verilog -remove_internal_net_bus -equal_ports_nets.
Also you need the set_fix_multiple_port_nets –all -buffer_constants .
Yawei
Reply #2 - Feb 27th, 2007, 5:39pm
There is another solution.
set verilogout_no_tri ture
set hdlout_internal_busses true
set bus_inference_style "%s\[%d\]"
Yawei
