The default these days is sst2 for transient, and psf for everything else (sst2 can only represent time domain data).
If you want to set it to psf all the time, you can use the SKILL function (in the CIW, or in your .cdsinit):
envSetVal("spectre.envOpts" "simOutputFormat" 'string "psfbin")
before starting ADE.
Why do you want to change it? By the way, don't have freedom to use all of spectre's output formats, because presumably you want the ADE waveform tool etc to be able to plot the results - and that only supports psf or sst2.
