Jul 19th, 2024, 12:37am
output format in analog design environment (Read 12965 times)
arsenal_he
Mar 02nd, 2007, 11:04am
hi,
i wanna know how to set the output format of spectre in analog design environment, such as psf or sst2?
thanks
arsenal
Re: output format in analog design environment
Reply #1 - Mar 3rd, 2007, 2:11am
The default these days is sst2 for transient, and psf for everything else (sst2 can only represent time domain data).
If you want to set it to psf all the time, you can use the SKILL function (in the CIW, or in your .cdsinit):
envSetVal("spectre.envOpts" "simOutputFormat" 'string "psfbin")
before starting ADE.
Why do you want to change it? By the way, don't have freedom to use all of spectre's output formats, because presumably you want the ADE waveform tool etc to be able to plot the results - and that only supports psf or sst2.
arsenal_he
Reply #2 - Mar 5th, 2007, 10:05am
THank you very much,  Andrew,
The reason i wanna switch to psf is that the dump interval of sst2 is much bigger than that of psf for a big design although it cannot be detected when for a small scale simulation. And since i dont know where to set the data-dumping interval, the only alternative is to switch back to psf bcoz i can see the results at the first sevel tens of ns instead of waiting for hundreds of nano-seconds to get the results of sst2.
thanks a lot
arsenal
Reply #3 - Mar 5th, 2007, 11:04am
Ah, the flushing problem with sst2. Yes, there's a PCR for that.
arsenal_he
Reply #4 - Mar 5th, 2007, 11:07am
hi andrew,
what does pcr stand for? where can i get it?
thanks
arsenal
Reply #5 - Mar 5th, 2007, 11:37am
pcr = product change request, I think; that is, someone's already requested a fix, but it's not available (you can't get it yet).
Reply #6 - Mar 5th, 2007, 1:17pm
Sorry I used internal terminology. Didn't think before I posted.
Anyway, if you were to log a service request with Cadence, the relevant PCR numbers (at least) are 4015013 and 886334 (these are the reference numbers for where this has been reported before to Cadence R&D).
arsenal_he
Reply #7 - Mar 5th, 2007, 1:53pm
hi  Andrew,
Thank you very much.
arsenal
Reply #8 - Sep 19th, 2007, 12:21am
Can I convert a transient simulation result in sst format into psfbin/psfbinf format?
Yawei
JoRobins
Give and it shall be
given unto you!
San Diego, CA
Reply #9 - Sep 29th, 2007, 7:44am
As far as I understand, no! And why/how do I know this?
One of the features that I've been trying out is the savestate feature in the transient analysis of Spectre. This allows one to run a tran simulation to a certain time point and then run a new simulation using the previous sim's final transient state (actually, it could be anywhere in the previous run as long as you've saved the state) as the starting point. Unfortunately this creates two different sst2 sim data files - one each for the 2 runs. If you try to plot the data in the second run, the starting time will not be from 0s but rather from the last time point of the previous simulation and there is no way to stitch together two sst files. However there is a way to stitch together two psf files (a sourcelink solution explains this) and if there was a way to convert from sst2 files to psf, I could have had a workaround. Unfortunately, no sst2 to psf conversion exists (at least according to the Cadence AE). They filed a PCR to at least allow stitching together of sst2 files...  :-/
