Sep 17th, 2024, 4:26pm
Idle pattern of sigma-delta A/D converters (Read 2588 times)
Mar 04th, 2007, 3:24am
Hi, Guys,
What is idle pattern? Is it always at half the sampling frequency for one-bit sigma-delta A/D or multi-bit sigma-delta A/D?
Yawei
vivkr
Re: Idle pattern of sigma-delta A/D converters
Reply #1 - Mar 5th, 2007, 2:53am
Dear Yawei,
The idle pattern is the response of a modulator to a DC excitation. On average,
it should be at Fs/2 for a modulator with 1-bit quantizer, and also for a multibit
one if I understand correctly because only 2 of the multibit levels are likely to be
used (closest to the midlevel) unless you add randomizing dither to break the tones, which
for a multibit delta-sigma is the standard way to remove idle patterns, and which
does not work well for 1-bit quantizers.
However, the topic is relatively complex. I would recommend that you look at
a book on introductory nonlinear systems. A good visualization is also offered
in the book "Understanding delta sigma converters" by Schreier and Temes in Chapter
2 (See Fig. 2.23).
Vivek
Reply #2 - Mar 7th, 2007, 6:26pm
Dear Vivek,
Thanks. Somebody recommended that book to me, too. I will try to get that book and read it.
Yawei
