Oct 18th, 2024, 9:14am
Plotting Vth variations (Read 10391 times)
Croaker
Mar 06th, 2007, 8:04am
Hello all, I'm wondering if anyone knows how to do a plot of how Vth varies due to process mismatch...  I guess I'm looking for a graph similar to a bell curve to show what Vth values I'm likely to get.
Thanks!  :)
Oh, I'm using Cadence.
Re: Plotting Vth variations
Reply #1 - Mar 6th, 2007, 8:32pm
Croaker,
  Not sure I understand exactly what you are looking for. Do you want
to plot distribution of delta Vt? Do you want to plot the correlation between
Vt and mismatch [delta Vt]? Do you want to plot correlation between Vt
and delta L, delta tox, ...? Do you want to plot correlation between delta
Vt and deltaL, delta tox, ...?  It should be possible plot the results, just
need a understand what you would like to plot.
Reply #2 - Mar 7th, 2007, 5:39am
In some processes, the VTH0 parameter is set by calls to a Gaussian distribution function.  In this case, you can just take the mean and std dev of the Gauss call and plot the distribution directly.
In some cases, though, TOX and VFB (which indirectly change Vth) are varied, and then you'd need to define what you mean by "Vth" ... and probably run some M-C simulations to "measure" it for your devices.
SATurn
Reply #3 - Mar 18th, 2007, 7:00am
The question is that how it is possible to plot (or print) the VTH for example in Cadence?
Saturn
Reply #4 - Mar 19th, 2007, 4:23am
SATurn wrote on Mar 18th, 2007, 7:00am:
What is VTH?  With subthreshold current, Id != 0 for Vgs < VTH, so you need to decide what you want to use as a definition of VTH: is it based on the value of drain current, the slope of the Id/Vg curve, ...  BSIM3/4 have a VTH output parameter, which is computed from VTH0 and other parameters, but it does not include things like GIDL that might actually change where a circuit designer would say the "threshold voltage" is based on the Id/Vg curve.
Croaker
Reply #5 - Mar 19th, 2007, 8:59am
Saturn
I do know how to plot Vth...or are you looking to find out?
Croaker
Reply #6 - Mar 19th, 2007, 9:03am
sheldon wrote on Mar 6th, 2007, 8:32pm:
Croaker,
Hi Sheldon, I want to have something like a pdf so I can see what my chances of getting certain Vths are.
Croaker
Reply #7 - Mar 19th, 2007, 9:04am
Geoffrey_Coram wrote on Mar 19th, 2007, 4:23am:
For the purposes of this thread, I will say Vth is the operating point value that spectre spits out.
Reply #8 - Mar 19th, 2007, 11:15am
Croaker wrote on Mar 19th, 2007, 9:04am:
If that's what you want, and you know how to access (plot) Vth, then I would expect you could do a Monte-Carlo and set your expression to be that Vth.  See "spectre -help montecarlo"
Croaker
Reply #9 - Mar 19th, 2007, 1:46pm
Geoffrey_Coram wrote on Mar 19th, 2007, 11:15am:
Yes, I've done that but it just shows a bunch of Vth values.  I was looking for something more histogram-ish.   Undecided
ACWWong
Oxford, UK
Reply #10 - Mar 19th, 2007, 3:19pm
in the cadence monte-carlo GUI, histogram ploting of your outputs (i.e. vth expression) is available under results, as are loads of other useful plot types.
Croaker
Reply #11 - Mar 20th, 2007, 5:44am
OK thanks, I'll look into that!  Sounds like what I wanted.
