Croaker,
Not sure I understand exactly what you are looking for. Do you want to plot distribution of delta Vt? Do you want to plot the correlation between Vt and mismatch [delta Vt]? Do you want to plot correlation between Vt and delta L, delta tox, ...? Do you want to plot correlation between delta Vt and deltaL, delta tox, ...? It should be possible plot the results, just need a understand what you would like to plot.
