Hi, Anguraj,
I think that a specific question is better, because we can discuss it with less misunderstanding and mistakes.
About your question, sure that the load is important in the simulation and field test. Normally the load should be defined in the related standard, that is JESD 815 in your case. Furthermore, I think the loading at the plus and minus inputs are almost the same in first order. They don't affect the cross points obviously.
Best regards, Yawei
