May 2nd, 2024, 11:20pm
IO CLK/CLKB Buffer SSTL_18 Compliance (Read 3317 times)
Anguraj.K
India
Mar 10th, 2007, 5:09am
Hi Experts,
I'm a new born baby to this Elite Community!
Greeting to all of You!
I need your help in the below question! I believe this would be a best place for me to get an answer
When I design a SSTL_18 compliant IO buffer for differential signals,
JEDEC spec (JESD815) : Differential Signals (CLK/CLKB)cross points need to be in the range power/2 +- 0.125V.
This is for a  test condition :
 clk buffer --> r 20ohm --> tline (50ohm)---- -->
        ---->across a 100ohm resistor ----> receiver
clkbar buffer --> r 20ohm --> tline (50ohm) ---->
Here I believe depending on the receiver i/p load , the cross point is going to vary.
So To test this scenario, how are you people handling without a solid receiver load (this varies from customer to customer who uses this IO pad)
Sorry for being too specific in my question.
Can anyone throw me some lights on their experience to this scenario?
Re: IO CLK/CLKB Buffer SSTL_18 Compliance
Reply #1 - Mar 20th, 2007, 2:52am
Hi, Anguraj,
I think that a specific question is better, because we can discuss it with less misunderstanding and mistakes.
About your question, sure that the load is important in the simulation and field test. Normally the load should be defined in the related standard, that is JESD 815 in your case. Furthermore, I think the loading at the plus and minus inputs are almost the same in first order. They don't affect the cross points obviously.
Best regards,
Yawei
