If you're doing analog modeling only, you should probably use Verilog-A, since it's supported by the major analog simulators (HSpice, Spectre, Eldo). I found it was fairly easy to learn Verilog-A by example -- look at the models on this site or elsewhere on the web. But grab a copy of the LRM as a reference.
