Jul 18th, 2024, 10:18pm
*internal* error after elaboration (Read 2150 times)
Pavel
Lausanne/Switzerland
Mar 12th, 2007, 2:14am
Elaboration of design terminates with internal error (please, see the picture).
Message content make think that there is somewhere some inconsistency between bus widths that connect different blocks.
I made short survey of design architecture at first two levels and didn't find discrepancy.
Am I right in my supposition and how to find the cause of error if design is complex and tool doesn't give
any index of error location?
Pavel.
Re: *internal* error after elaboration
Reply #1 - Mar 15th, 2007, 6:47am
I think you need to do what it tells you to do in the error message, and contact Cadence.
I found a few references to the error, but these were all due to things that have been fixed in earlier releases.
