Oct 3rd, 2024, 9:26am
Pages: 1 2
Dummy transistor and decoupling capacitor (Read 16548 times)
dandelion
Mar 13th, 2007, 1:51am
We have always add dummy transistors for the devices which need good matching.I wonder how to connect these dummy transistors. Connected the dran, source,bulk,gate together,then tied to VDD? Or Connected the dran, source,bulk,gate together,then tied to GND? Or put them floating? Or connect them as decoupling capacitor?
Always connecting them as decoupling cap have any risks?
I would be happy to hear your advice.
adesign
Re: Dummy transistor and decoupling capacitor
Reply #1 - Mar 13th, 2007, 3:52am
For pMOS connect drain, gate, source, bulk to VDD. For nMOS connect these to ground.
dandelion
Reply #2 - Mar 13th, 2007, 5:34am
It is encouraged to do this?
Croaker
Reply #3 - Mar 19th, 2007, 9:06am
For dummy transistors, is there any point in making the length greater than minimum, even if the MOSFETs they are shielding are longer than minimum?
Reply #4 - Mar 21st, 2007, 7:19pm
dandelion wrote on Mar 13th, 2007, 5:34am:
No risk if you keep the gate-source voltage and gate-drain voltage not greater than the supply voltage.
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #5 - Mar 22nd, 2007, 8:50pm
Why not put them floating, I think doing this may be better.
krishnap
Reply #6 - Mar 23rd, 2007, 2:47am
One of the terminals could be connected to the adjascent active transistor and gate and other terminal is connected to
ground or power based on NMOS 0r PMOS respectively.
As Croker suggested dummy device can be of minimum length.
Floating device may not be advisable, and  it is better to tie all the devices to some bias ..
avlsi
singapore
Reply #7 - Mar 23rd, 2007, 4:33am
dummy is helpful only when u need good matching. generally, I connect gate of the PMOS(dummy) to VDD, so that its OFF always and NMOS vice versa.
In my chip, I shared the drain or source of dummy transistor with the real transistor to remove the etching problem during fabrication. This really helps a lot in diff apms in reducing offset.
Winners never Quit,Quitters never Win
Croaker
Reply #8 - Mar 23rd, 2007, 8:10am
krishnap wrote on Mar 23rd, 2007, 2:47am:
I was actually asking...I think it can be minimum length in all cases, but if anyone knows differently, please let me know!
chase.ng
penang/malaysia
Reply #9 - Mar 23rd, 2007, 10:13am
A question over here, if the PMOS or NMOS dummy has shared drain/source with other device and the gates are tied to the respective power supply to shut them off, will any ESD event like the CDM break those gates and short those devices since those gates are directly connected to pads? I once do that in a test chip which was never subject to ESD test, I wonder is that ok for production chip, anyone has experience on this?
Thanks and Regards,
chase
Chase
View Profile chase.ng   IP Logged
krishnap
Reply #10 - Mar 24th, 2007, 3:54am
Hi Chase,
Some of the production chips had this configuration, where
gate and other terminal connecting to power or  ground.
Krishna
chase.ng
penang/malaysia
Reply #11 - Mar 26th, 2007, 6:28pm
Hello Krishna,
Thanks for the info. Are those fets ESD protected in any other way? Or they just wired the gates to power supply?
Anyone else had experience on this?
Thanks and Regardsm
Chase
Chase
Reply #12 - Mar 26th, 2007, 8:22pm
chase.ng wrote on Mar 26th, 2007, 6:28pm:
Hello Krishna,
Thanks and Regardsm
Chase
I think the power supply pads have ESD protection. So don't worry about ESD although we often wired the gates to power supply.
Reply #13 - Mar 26th, 2007, 8:32pm
Croaker wrote on Mar 23rd, 2007, 8:10am:
Good question. I want to know the answer, too. One simmillar question, the above idea is very useful for capacitor matching. I use very narrow metal as dummy surrounding those caps. However, I know some big companies use dummy cap very generously. For eg., in a 1.5bit/stage pipelined ADC, each MDAC has 4 unit caps totally. They use 12 more unit caps as dummy cell. The former 4 unit caps are put in the center, while the other 12 are put surrounding them. They construct a 4x4 unit cap array and consumes much more area.
Anyway, I want to reduce the area as more as possible. Any comments are appreciated.
Yawei
Croaker
Reply #14 - Mar 27th, 2007, 6:20am
Regarding the caps, I think you are OK as long as there is some surrounding metal.  No need to put big dummy caps around the edges.
Pages: 1 2
