Jul 18th, 2024, 4:29pm
Singular Matrix Errors in Cadence VHDL AMS-ncsim (Read 4545 times)
badams
Mar 13th, 2007, 8:18am
Hi
I was trying to model some transistor level circuits in VHDL AMS using Cadence Spectre VHDLAMS.
I have no clue in how to debug the
"Error found by spectre during DC solution estimation, during IC analysis,
      during transient analysis `amsAnalysis'.
   Matrix is singular (detected at 'uInv.A1.QB' and 'uInv.Output')
ncsim:*E, RNALER: simulation terminated due to analog error"
Thanks in advance. your help is awaited.
Re: Singular Matrix Errors in Cadence VHDL AMS-ncs
Reply #1 - Mar 14th, 2007, 4:45am
I don't understand why you are using VHDLAMS if the circuits are transistor level ...
You probably need to investigate the uInv (ulnv?)  model.  Is it transistor-level or behavioral?
badamsssl
Reply #2 - Mar 14th, 2007, 8:27pm
Geoffrey_Coram wrote on Mar 14th, 2007, 4:45am:
HI
Thanks for your reply
Iam Modeling a charge based transistor Model accounting to deep submicron effects in vhdl ams and validate its functionality by some benchmark circuits
My model is a purely behavioral one with some simultaneous statements., I was trying to build an inverter using the transistor model. and the outputs were fine for an inverter but it gives the said Singular matrix error message.
Your help is awaited and iam desparate to solve that problem
Srinivas
Reply #3 - Mar 15th, 2007, 9:07am
It's almost certainly a modeling error with your simultaneous statements, but I don't have any experience with VHDL-AMS to suggest how you go about debugging it (nor what the common mistakes are) in that language.
