fangjh
hefei china
Hi:jim I have design 0.13um bandgap, and the output voltage is 0.525v, the chip's performance have some problem , you should be care the start up circuit 's margin, otherwise the bandgap should not be start normal, other parameter is ok, 1V-1.4v: variable 4mv and temp 0-85c : about 3mv.
