Oct 18th, 2024, 12:40pm
0.13um bandgap (Read 5638 times)
jim
0.13um bandgap
Mar 14th, 2007, 8:13pm
Dear all,
We want to design the bandgap reference with 0.13um process 1.2v device, Is it ok?
Thanks in advance,
Jim
SATurn
Re: 0.13um bandgap
Reply #1 - Mar 18th, 2007, 7:48am
It highly depends on the specs you wish achieve. In general, it is possible to design very low-voltage BGRs, even below 1.2V (you can have a look on IEEExplorer). In this case of course the reference voltage would be smaller than the usual value (i.e., 1.12V).
SATurn
jim
Re: 0.13um bandgap
Reply #2 - Mar 19th, 2007, 12:43am
Dear SATurn,
Thanks a lot for your reply,It's a pity that I haven't a IEEE account, so I couldn't download paper from it . Could
you please forward some papers to me?
email address: fujj_2003@163.com
Thank you very much and best regards!
Jim
chase.ng
penang/malaysia
Re: 0.13um bandgap
Reply #3 - Mar 20th, 2007, 12:49am
The theoritical minimum headroom for current mode bandgap can goes down to vbe+vdssat which can be lower than 1 V. However, as the voltage goes lower, I found it harder to achieve good accuracy.
Chase
Chase
View Profile chase.ng   IP Logged
SATurn
Re: 0.13um bandgap
Reply #4 - Mar 21st, 2007, 10:35am
Let me try.
SATurn
fangjh
hefei china
Re: 0.13um bandgap
Reply #5 - Apr 8th, 2007, 6:03pm
Hi:jim
      I have design 0.13um bandgap, and the output voltage is 0.525v, the chip's  performance have some problem , you should be care the start up circuit 's margin, otherwise the bandgap should not be start normal, other parameter is ok, 1V-1.4v: variable 4mv and temp 0-85c : about 3mv.
jim
Re: 0.13um bandgap
Reply #6 - Apr 27th, 2007, 12:36am
Hi fangjh,
Thanks a lot for your reply.
Jim
Re: 0.13um bandgap
Reply #7 - May 23rd, 2007, 5:44pm
Have you considered doing a 1.2V output BG (flattest thermal response) and using the I/O transistors? Also, if you dont have the 1.6V (give or take) to run that, you can use charge pumping to create it internally.
