Jul 19th, 2024, 12:24am
how simulate veriloga model in DC (Read 2193 times)
Pavel
Lausanne/Switzerland
Mar 15th, 2007, 3:01am
Hello
I didn't find in documentation how can I simulate veriloga/verilogams models in DC.
I tried following approach:
1. created veriloga model
2. created symbol for it
3. created schematic testbench - dc stimuli + model
4. invoked ADE
5. in ADE changed simulator for ams
6. choose dc analysis in ADE
But there are no any parameter to specify - no source to sweep, start/stop/step, etc.. (please, see the picture)
Pavel.
Re: how simulate veriloga model in DC
Reply #1 - Mar 15th, 2007, 6:39am
AMS Designer does not support (currently) doing a DC sweep. Bear in mind that the digital part would need some time to react to a changing parameter or voltage, so it doesn't make so much sense to do a DC sweep with a mixed-signal simulator as it does with a pure analog simulator (where you can calculate the DC by removing the capacitors and shorting the inductors).
So the only choice you have is to do the DC operating point.
