Oct 3rd, 2024, 5:26pm
Threshold Voltage (Read 4366 times)
avlsi
singapore
Threshold Voltage
Mar 21st, 2007, 1:29am
    As we increase the channel length, why is that the threshold voltage decreases?  What is the reason behind this?
Thanks in advance.
Winners never Quit,Quitters never Win
Michiel
Enschede, the Netherlands
Re: Threshold Voltage
Reply #1 - Mar 22nd, 2007, 4:25pm
avlsi wrote on Mar 21st, 2007, 1:29am:
Thanks in advance.
There are many factors that influence the threshold voltage. Some basic ones are described in books like "Design of Analog CMOS Integrated Circuits". http://www.designers-guide.org/Books/
Personally I don't even want to know all the physics behind it.
There is only one reliable way to make sure that two transistors have about the same (nominal) threshold voltage. Use identical parameters and layout.
krishnap
Reply #2 - Mar 23rd, 2007, 3:02am
Because of short channel effects VT decreases as channel length decreases.
Exception to this is Reverse short channel effect, where VT increases as channel length reduces.
Best regards,
Krishna
mg777
Reply #3 - Mar 23rd, 2007, 8:09am
As L decreases the drain and source depletion regions steal more of the gate's field lines, so the VTH actually decreases while the subthreshold conduction increases. OTOH if tox decreases faster than L, then you put the gate back in control (Cox increases) leading to a better trade-off between VTH and subthreshold slope.
M.G.Rajan
www.eecalc.com
mc66
Reply #4 - Mar 29th, 2007, 7:11am
there have roll off curve for vt
eg: when L is between 0.13 ~ 0.4(just estimated, 130mn technology) , vt is decrease with L decrease (SCE effect)
     but when L is between 0.4um and above , vt is incresae with L decrease (RSCE effect , halo implant cause this)
SATurn
Reply #5 - Mar 29th, 2007, 12:27pm
By reducing the device length, the field created by drain (or source) can bend the fermi level inside the substrate and attract some minority carriers. There is a very good discussion on this issue in Taur's book.
SATurn
