Sep 17th, 2024, 6:29pm
question about the connectRules (Read 2557 times)
Aigneryu
Mar 27th, 2007, 5:20pm
 Recently while I tried to simulate my circuit with AMS, I realized that I need 2 different voltage level in the digital domain, say, high swing and low swing. Not like spectreVerilog, I do not know how to assign different connect modules or rules to different A/D interfaces. Can anybody point out which document I should refer to? I read some of the help files, and was confused because it is said that the discipline will affect the connect rules.
Sincerely,
jbdavid
Re: question about the connectRules
Reply #1 - Apr 4th, 2007, 1:51am
the discrete discipline determines the connect module used..
what I generally do is use 2 logic disciplines..  - (neither is "logic" because thats a reserved work in systemverilog)
so I use a cmos_logic15 for the core, and cmos_logic33 for the io
a pretty full description of different cml swing discipline types is described in a paper presented at BMAS in 2006, which lists example connect rules, and connect models I used recently..
http://www.bmas-conf.org/2006/4.1_paper.pdf
HTH
jbdavid
Aigneryu
Reply #2 - Apr 7th, 2007, 7:09pm
Thank you so much, this is exactly what I need.
Sincerely,
