Alm
I am tryin to understand the following behavior:
In the attached circuit of a simple 5 transistor diff-amp, the bias voltage Vb is held constant.
Now I am increasing the width of the pair w1-w2. As width increases, initally gm of those mosfets increase in proportion to sqrt(w1). I believe this is because as current is const, due to const Vb,
gm = sqrt(2 * Mn * Cox * W/L * Id)
However, after a point even when the Width of the mosfet pair increases, gm1 remains constant (see attached figure).
Could anyone help me understand why does gm1 become constant.
Is this the so called 'strong inversion' where gm gets poor?
-Alm
