Jul 21st, 2024, 1:23am
using spectre to build the pll behavioral model (Read 2848 times)
calven
Apr 07th, 2007, 9:01am
hi!
should i build the models of basic cells such as vco using verilog_a or verilogams if i use spectre to build the pll mode?i find that these cells are offered  in the libs such as functional,ahdl and rfLib bu virtuso, can these cells not fully describe the characters of real cells?
thanks a lot!
Re: using spectre to build the pll behavioral mode
Reply #1 - Apr 7th, 2007, 8:18pm
Calven,
  If you are going to build a PLL model for Spectre, then the models need to written
in Verilog-A. AMS Designer supports Verilog-AMS. There are some model templates,
on this site under the Verilog-AMS link
    http://www.designers-guide.org/VerilogAMS/
There is a lot of information about PLL modeling under the Analysis link including
   http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf
Ken's classic paper of behavioral modeling of PLLs. One other library that may be useful
in the Cadence libraries is bmslib it contains Verilog-A primitives for logic gates that can
be used to create Phase/Frequency Detectors.
calven
Reply #2 - Apr 8th, 2007, 9:21pm
thanks a lot!
what is the difference between Verilog-A and VerilogAMS?which one should i choose?
Reply #3 - Apr 9th, 2007, 3:52am
Verilog-A is the "analog only" subset of Verilog-AMS, which is a full analog and mixed-signal language and includes (in principle) everything from IEEE 1364 Verilog.
