Oct 2nd, 2024, 11:15am
Multiple bandgap reference in IC (Read 2147 times)
chase.ng
penang/malaysia
Apr 09th, 2007, 5:00pm
Hello all,
Is it better to have only 1 centralized bandgap reference circuit and use current mirror to bias other circuits on the chip? Or is it better to have separate reference for separate circuits on the chip?
There are some arguments regarding trade-off between reliability and power. Some argue that by using multiple bandgap, I will get better reliability becuase in case one of the bandgap fail, only one part of the IC will fail.
But how often do these bandgap references fail? Anyone encounter any problem with a bandgap reference before?
Thanks and Regards,
chase.
Chase
View Profile chase.ng   IP Logged
Re: Multiple bandgap reference in IC
Reply #1 - Apr 9th, 2007, 7:09pm
Hi, Chase,
I prefer a single bandgap which generate all required voltages and currents. The bandgap output is often an indication that the chip functions when we test in lab or test for mass production.
Now bandgap design is very mature and reliable. So don't worry. Furthermore, a product cannot be deliver to customers if only one part of the IC fails. So separate bandgap reference on a chip makes nonsense.
Yawei
Reply #2 - Apr 12th, 2007, 8:50pm
One bandgap and current distribution of bias - total agreement here.
Also Power up and power down are more predictable if it is all under the control of one bias box.
The only exception here - some RF type chips where noise in the bias distribution system is critical.
Ergo, ae you fighting thermal noise in bias currents? Hopefully not, because current source are very noisy things in the LNA-Mixer corner of the world.
