Jul 20th, 2024, 3:25pm
ultrasim vs spectre (Read 10618 times)
arsenal_he
ultrasim vs spectre
Apr 09th, 2007, 6:09pm
hi,
i am runing some simple simulation using ultrasim and spectre.
For a transistor with fixed biases, spectre shows id=260uA while ultrasim only gives out 50uA with the same model and corner and highest accuracy setting.
And the spice model shows that spectre simulation gives the correct results, then what can i do such that ultrasim runs fine?
thanks
arsenal
Re: ultrasim vs spectre
Reply #1 - Apr 10th, 2007, 6:05am
Arsenal,
  You need to provide more information about your circuit and any
warnings in the log file. In particular, was the dc operating point
calculation correct?
                                                         Art Schaldenbrand
arsenal_he
Reply #2 - Apr 10th, 2007, 11:19am
hi art,
thank you for your reply.
I didn't find any warnings but the vth of ultrasim simulation is 0.658v while that of spectre is only 0.420v.
Then why is so big difference of vth?
thanks
arsenal
sheldon wrote on Apr 10th, 2007, 6:05am:
Arsenal,
                                                         Art Schaldenbrand
Reply #3 - Apr 10th, 2007, 12:11pm
Do your models include WPE or STI stress effects (parameters SA, SB, SC)?
arsenal_he
Reply #4 - Apr 10th, 2007, 1:31pm
hi Geoffre,
I found some warnings complaining lack of sa1 so ultrasim use sa instead. BUt I did'nt find any sa1 or sa in the model file. And I have checked both the netlist of ultrasim and spectre, both of them have the parameters of SCA, SCB, SCC
thanks
arsenal
Geoffrey_Coram wrote on Apr 10th, 2007, 12:11pm:
« Last Edit: Apr 10th, 2007, 5:42pm by arsenal_he »
Reply #5 - Apr 12th, 2007, 4:39am
SA/SA1 are instance parameters, meaning that the instance should have values that indicate how that particular device is laid out; AD, AS, PD, PS are also instance parameters.  The model file describes common parameters.  If ultrasim is using the wrong values for the stress parameters, then it will incorrectly compute the shift in threshold voltage due to stress.
If it's a small test netlist, you could delete all the sa/sb/sc parameters and see if you get the same threshold voltage.  Then we can work on seeing if we can fix the parameter names.  Eg, "sa1" is not an official BSIM parameter, it is part of a foundry-specific STI stress model; there are values SA1 through SA9 for up to 9 gate segments.  It may be that ultrasim doesn't support these unofficial parameters.
arsenal_he
Reply #6 - Apr 12th, 2007, 11:35am
hi Geoffrey,
thank you very much.
I found that it was due to the calculation of SCA,SCB and SCC, which should change as to W/L, but my those parameters in my pdk are fixed! Still i don't know where to get a new pdk for tsmc65gp
thanks
arsenal
Geoffrey_Coram wrote on Apr 12th, 2007, 4:39am:
« Last Edit: Apr 12th, 2007, 3:18pm by arsenal_he »
Reply #7 - Apr 13th, 2007, 6:45am
You may need to get a layout-extractor that supports WPE (SCA,SCB,SCC).
arsenal_he
Reply #8 - Apr 13th, 2007, 3:35pm
ya, im using qrc to do the RCX, and it seems SCA,SCB and SCC affect vth too much! i did an experiment and the pre-layout vth is about 470mv while the post-layout is 690mv!!! How can i minimize the discrepancy in layout?
thanks
Geoffrey_Coram wrote on Apr 13th, 2007, 6:45am:
Reply #9 - Apr 13th, 2007, 10:22pm
Arsenal,
  Can you modify the transistor layouts? These parameters are a
function of layout. BTW, did a quick search and found an interesting
paper that might give you insight into what needs to be changed,
      http://www.ieee-cicc.org/06-8-6.pdf
arsenal_he
Reply #10 - Apr 17th, 2007, 3:47pm
Sheldon,
Thank you very much.
arsenal
sheldon wrote on Apr 13th, 2007, 10:22pm:
Arsenal,
