Jul 20th, 2024, 5:21pm
shunt peaking configuration (Read 458 times)
golden_falcon10
Apr 17th, 2007, 12:57pm
I try to design High Frequency Amplifier, I use shunt peaking configuration as shown in attachment.
How …?
1-I calculate the total capacitance at the drain of M2.
2-Can I calculate it using Dc Analysis using Cadence Spectre Calculator/tools because there is many cap like (Cgd, Cdg, Cdd…) in dc operating point how I choose between it to calculate the total capacitance at the drain of M2.
3-the value of this capacitance take –ve value >>>>HOW???
Re: shunt peaking configuration
Reply #1 - Apr 18th, 2007, 4:07am
If you're manually adding up Cxy, you need to pay attention to the definition as Cxy = -dQx/dVy, see the minus sign.
Spectre (and other simulators) support a CAPTAB option that can print the total capacitance at a node, but this will give misleading numbers if there is a small drain resistor (you have to find the capacitance on the internal drain of M2).
Another method is to put a small-signal source on the drain:
i2 (0 m2_D) isource dc=0 mag=1
then measure the small-signal (ac) voltage, and compute:
Ceff = imag(1/vac(m2_D)) / (2 * pi * freq)
where "freq" is the frequency where you measured the ac voltage.
This is because I = Y V, where the admittance Y is the parallel combination of the effective conductance and capacitance:
Y = Geff + j w Ceff
I = 1 (mag=1 on source i2)
Thus, Y = 1/V, and imag(1/V) = imag(Y) = w Ceff, so
Ceff = 1/ (2 * pi * freq) * imag(1/V)
